-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   3.6 stalling problem (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1167310-3-6-stalling-problem.html)
Kevin Stewart 09-21-2024 05:34 PM
Hi guys I have an 82 911 with a 93 3.6 starts and runs great after a few minutes I gurgles and tries to stall. If I turn it of and restart it runs great for a couple minutes then repeat again. Any ideas? Thanks Kevin
LM964 10-08-2024 02:51 AM
Does this only occur when the engine is warm/hot - like sitting in a queue and watching the temp increase?
Kevin Stewart 10-08-2024 07:17 AM
You fire it up drive for a block and it starts stalling will not rev, like no fuel or a choke is on
LM964 10-09-2024 05:08 AM
Not sure then. The carbon cannister under the rear left wheel arch cover is part of the fuel evaporative system - collects fuel vapors from the fuel tank when idling/stationary. When driving fuel vapors are burned by the engine. An old or faulty cannister can cause starting, idling, acceleration problems when the engine is warm. Not normally a cold day problem - typically hot day and/or prolonged idling.
I did experience this in long traffic queues in the middle of a hot French summer. New cannister and all problems disappeared. However, this may not at all be your issue (but worth keeping in future mind). Turbofan has given main pointers above.
