"O Gruppe 13"
IDGAF27's Avatar
Send a message via Skype™ to IDGAF27
964 engine bay question
Happy holidays....
Have two questions about 964.
1. Speed references sensor- plug is broken. Any chance you know/have collor diagram how to connect wires?
1-2 photo
2. What goes here? I cant remember. Will search but maybe any of you know by heart.
2-3 photos
See photos for reference.
G-Man
89 964 C4
86 930
Old 12-29-2020, 07:26 AM
Merry Christmas and Happy Holidays!
2. I have the same vehicle - 89 964 - there’s not a white fitting on my bracket. Looked around - can’t find it. See photo.
1. I can’t see inside the harness to see the wire colors.
Not sure I was much help.
John
1989 Carrera 4 Coupe - Guards Red
1984 944 Coupe - Alpine White
Old 12-29-2020, 10:04 AM
budge96's Avatar
If you cannot put your hands on a new speed ,reference sensor and wire to replace or
check order maybe remove the rubber on other plug side and check color sequence
they should be the same .
The white plug you found goes to a hose coming from behind the crossmember
that pulls vacuum from the manifold for the braking system , goes up to your booster
on the front suspension.
GT2
RS 3.2
RSCS 3.8
R 2.5 Twin Plug
Old 12-29-2020, 07:06 PM
Scottsdale Arizona USA
Happy New Year 2021!
Looks like it is time to update your crank ref sensor and plug end.
3, 2, 1 from left to right.
CHT sensor and plug are the same except white plug and uses 2 pins
Old 12-31-2020, 04:41 PM
zdr zdr is offline
Hi - I'm trying to do this update and wondered how the best way to remove the grommet that the wire runs through might be (without tearing it). From above or below? Thanks
Old 06-03-2025, 01:39 PM
