-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   993 odometer not working (http://forums.pelicanparts.com/porsche-964-993-technical-forum/123346-993-odometer-not-working.html)
indra gunawan 08-14-2003 05:52 AM
i got problem w/ my 993 C2 TiptronicS odometer.
The speedometer is working fine, but the odometer isn't working at all. Is anyone know how to find the problem? The sender or the gear of the odometer ?
Rick Lee 08-14-2003 11:02 AM
If you've ever reset the odometer while the car was in motion, that's supposed to be a bad thing and can strip the gear in there. Actually, that may only affect the trip meter. You probably have an electrical problem there.
indra gunawan 08-14-2003 10:36 PM
i never reset the odometer and the speedometer is still in original condition, never open. The trip on the onboard computer (tachometer) is working properly.
expat 08-17-2003 01:23 AM
Come-on guys. Someone has to have an answer to this...mine (964) has the same problem....speedo ok, mileage and trip meter not operating.
Any help please.........
expat 08-17-2003 01:37 AM
Maybe this might help. Good pictures and link for parts to repair.
Anyone know how close the inside of the 964 and 993 speedometers are in comparison to 911's?
http://forums.pelicanparts.com/showthread.php?s=&threadid=101713&highlight=odomet er
Imcoz 07-08-2008 09:44 AM
VDO parts available from these guys for the DIY repair...
www.odometergears.com or via credit card over the phone. 757-593-3478 or 757-771-6694
Good how-to link shows early C2 gauge...
http://p-car.com/diy/odometer/
mdbrd 10-21-2008 11:19 AM
964 odometer <60,000 miles
This is a HOT issue for me....1991 964 odometer not working. Today I filed a complaint because I'm hoping for a recall. The info I have is from "101 projects for your 911", which I've seen cited on here previously. ".......almost guaranteed to fail......perhaps most predictable failure.......2 design flaws....plastic gears and pot metal gear pressed on the shaft of the odometer." Choices to correct the problem are
1obtaining spare used gauge(s) and trying to fix it yourself which you'd almost have to be a certified mechanic ($100)
2Take it to a dealer so they can send the part out to have it fixed($350)
3 and my personal favorite, Replace the whole speedometer yourself ($150) unless you have a tiptronic transmission ($325), (no longer my personal favorite)
roofbolter 04-28-2010 09:34 AM
Thanks to Brain for providing the DIY break down, this is an easy fix.
How to fix a broken odometer
Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478 or via credit card over the phone. 757-593-3478 or 757-771-6694
