-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   replacing window switch in 993 (http://forums.pelicanparts.com/porsche-964-993-technical-forum/133097-replacing-window-switch-993-a.html)
tshih 10-25-2003 04:39 PM
Anyone knows if it's necessary to remove the door panel trim to replace the passenger's switch on the driver side (electric window switch) in a 1996 993? Can one just pop the old switch out of the panel and replace each wire connector with the wires being long enough to attempt it that way?
Tom
tshih 10-25-2003 08:19 PM
Hi,
I just popped out the old broken switch and it was a simple unplug the wire socket and push the new switch back in. I used a plastic ice scraper to pull out the old switch from the bottom edge without tearing the door trim. Almost as simple as replacing a light bulb.
trader220 11-04-2003 08:43 AM
I used a plastic knife from a fast food joint since I carry extras. They tend to fail often
