LinkBack | Thread Tools | Rate Thread |
KYUKYU3
Advice with paint work on OEM metallic finishes (Zenith Blue, Arena Red, Silvers...)
I have a few new exterior mods that need paint, as well as the front bumper needing a respray.
My car is a Zenith Blue. It is a metallic based finish. I love metallics until you need to do paint work. The PO did a respray on the passenger side which is top notch work. I have had a few metallic cars and gotten paint work done so have a trained eye on paint work. You cannot tell other than with a paint meter and if you are in direct sun light in a certain angle where you can see an ever so subtle difference in the shimmer which is from a difference metallic base as I am sure they did not use the crazy expensive OEM Porsche paint. I have heard that Porsche used a water based metallic finish on our 993s. I also heard that since then most paint shops use a organic based metallic finish, with the exception of California which has prohibited the use of organic paints within the last couple of years. I have been to a few body shops to get estimates and understand what they use. PPG and Dupont are two paint supplier names. I know a full respray is the only solution to get perfection, but I don't want to drop the coin on that. Do any of you have had paint work done on your metallic beauties and what you found to be a great outcome? Any input for those that have Zenith Blue? Last edited by samurai_k; 01-12-2018 at 07:28 AM.. |
I can’t help you with paint type or brand but a good color match is possible. Years ago on my old SC I needed some touch ups to the metallic silver, the paint shop did a perfect blend, I was impressed.
Kurt |
KYUKYU3
Thanks @KNS. I have a new decklid (with duck) and a front bumper that need paint. Do you think I should first try to have them paint it and if it doesn't match then go for a blend into the other panels? Or do you think a blending into the other panels is necessary?
messing with other panels is opening up a whole can of worms.
find a good shop that has done this work before. and drop the bumper off to them. this is very very common job. I had my bumper resprayed to have the bumperettes filled, i removed the bumper brought it to them, they prepped it, sprayed it, and it was a match. you may want to order new bumper gasket too. thats a ton of fun putting that back on.
1995 993 C2 |
KYUKYU3
Thanks for the input. Very helpful.
