Triptronic to G50 conversion
Is it possible to convert a 964 triptronic to a G50. My guess would be yes but the following items would need conversion.
Transmission of course
Speedometer
Gear shift with linkage
maybe the bezel around the shifter
But what about the DME
Old 02-12-2004, 06:02 PM
maxnine11's Avatar
not sure of the electronic logistics of the swap; but see missingfrom the list:
-flywheel
-clutch/pressure plate assembly
-throw-out bearing and fork
-pedal assembly
-hydraulic clutch cylinders and hoses
max
max
Old 02-12-2004, 06:09 PM
Bill Verburg's Avatar
The tip wiring harness doesn't have the same provision for activating the back up lights.
Bill Verburg
Old 02-13-2004, 02:13 PM
At one point, I looked at a 964 with a 5sp. I noticed the car had a OBC. I mentioned to the seller that it was rare to see a OBC on a manual trans car. He said it was because the car was a TIP originally. The conversion was not that difficult, according to him. All bolt-in...
Chris
Old 02-14-2004, 11:36 PM
