driver side heated seat problem
My driver side seat heat doesnt heat. The passenger side does. Any tips on checking the seat out? Too poor to move to Fla. for winter. '95 c4 cab.
Old 11-11-2004, 06:34 PM
project935's Avatar
Check the wiring, connectors, and fuses - should be easy stuff to do w/o removing the seat.
Pull and check the switch with a meter - they go bad.
If those checks don't fix it, then the seat probably needs to be removed and the upolstery pulled to check out the heat element.
Project935
Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06
Gruppe B #101
What's next?
Old 11-12-2004, 05:03 AM
