964 intake manifolds
were there plastic intake manifolds used on late 964s? my 91 is aluminum. also i recall 993s being aluminum also
Old 01-17-2005, 06:51 PM
plastic is late model
Old 01-17-2005, 09:04 PM
late 91 is when they started
jc964rs's Avatar
they have better design and larger intake size
What can you dream on when owning an RS ?
http://www.ma964rs.com
Old 01-22-2005, 04:14 AM
Not Quite Banned
Thomas Owen's Avatar
Is it possible to replace the metal intakes with plastic for any gain? Is it a matter of just exchanging the manifolds themselves?
Thomas Owen
1972 911T
1972 911S
Old 01-28-2005, 04:56 AM
Rouxzy's Avatar
I have just researched this because I just put a 3.6 in my car. What I found is that there is no benefit in power between the two. The only gain you will get with the plastic is if you also replace the throttle body that came with the plastic, (which was changed along with the plastic). So, unless you are doing it for weight savings then you will not gain a thing.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 01-30-2005, 03:19 AM
Bill Verburg's Avatar
While there is no difference in the factory rated power, the plastic are lighter, flow more equally and transfr kless heat to the intake charge.
As noted the center metering section was also changed so to change the manifolds the meter must also be changed. Some change it to the 993 mass measuring system.
Bill Verburg
Old 01-31-2005, 11:34 AM
