Boost Spring
How do I put in boost spring? Just unbolt wastegate and open it?
1991 Turbo Polar Silver. 415 HP of pure FUN |
You will have to remove the wastegate first.
Then yes, you unbolt the nuts around the round part of the wastegate. Be careful..... it will want to fly apart on you. An extra pair of hands is helpful in getting it all back together. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Ditto AFJuvat - I clamp the wastegate in my drill press before undoing the peripheral 10mm nuts. Others use a strap wrench or similar. You don't want to have your head in line with the top of the WG when you unbolt the last nut! And be sure to wear your safety glasses.
993 |
