993 Secondary air induction supply = top end rebuild
My check engine light came on and I have been informed that my secondary air induction supply needs to be replaced (basically a top end rebuild) from carbon build up. A 993 factory problem-
Has anyone had any experience with this?
Old 06-07-2005, 07:01 PM
grmnxtc's Avatar
Known issue. Check out a DIY procedure at p-car.com
Don't know if mine is affected (probably all 993's are) but a '95 has OBD1 and does not throw the CEL (check engine light).
http://p-car.com/diy/sai/1/sai.htm
Clive.
Clive.
GRMN XTC is a '95 993 Cab.
Guards Red/Cashmere
Old 06-07-2005, 09:35 PM
Bill Verburg's Avatar
A constant topic of discussion over on the Rennlist 993 board.
there are several different failure modes
  • pump
  • lines
  • blocked ports
most can be alleviated w/o a top end rebuild, but in the worst case scenario, worn valve guides contribute to the blocked ports in the exhaust, this leads to a full to end rebuild
Bill Verburg
Old 06-08-2005, 04:51 AM
kang's Avatar
See this thread: 1995 or a 1996 993 ?
Read my description of the problem in the 9th post down.
Downshift
Old 06-08-2005, 08:31 AM
Porscheologist's Avatar
Cool
This is a HOT topic. Do a search for CEL, carbon, obdII etc. and you will get hits that discuss this in depth. Also a topic over at Rennlist and even in Excellence magazine!!
Hot Hot Hot!
Do NOT get a top end re-build until you read these posts and get informed. It could save you big $$$!
Just me thoughts...
1995 993 White Coupe (Awesome!)
1983 911SC (Sold!)
1981 924 (Sold!)
1978 924 (Sold!)
Old 06-13-2005, 09:44 PM
