Porsche Crest Which Cooling Fan fits?
Hi all, I have a 75 911 with the 11 blade fan/alt. I also have a 12 blade 964 fan/alt combo. I have the complete assemblies, fans,housings and alternators for both types.
I've heard you can use the later 964/C2 fan/alt assy in an earlier 911 using a c2/turbo fan housing. Does anyone know about this?
Old 09-11-2005, 06:04 PM
AFJuvat's Avatar
Yes, they will swap over. You may have some fitment problems with the engine shroud. Also, monitor engine temps - you may need to swap the crankshaft pulley to get the fan to spin fast enough.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-11-2005, 06:31 PM
Cool
Thanks, I will pick up the fan and shroud on Wed. Is there anything I should make sure I get also.
FYI. I have the c2/964 pulleys,nuts, shims rear mini fan housing, Large fan housing with a 964 engine shroud and a bushing that replaces the bearing on the alt shaft. I also have the original bearing.
My car has the dual crankshaft pulley for the California emissions smog pump (Gone Long Ago) and A/C pump also gone.
I plan on using the early S (Red) engine shroud. I was able to fit the 964 fan housing onto the engine but the depth was to great. I have sheet metal ducts left and right Fan to Heat exchangers (911).
It appears the C2/Turbo fan housing is the same size depth as the 911. How about the diameter?
Any help is welcome....
Mark
Old 09-11-2005, 06:52 PM
