Doug751's Avatar
964 Headlights; What is the best available option for upgrade?
How can I improve my lights, 1992 964 C2, standard H5 USA lights.
What is the best upgrage?
What is the cost?
Where do I buy it?
Do I need to rewire or add relays?
Do I need to paint the trim rings?
Thanks!
-Douglas Greig
Old 09-08-2005, 06:57 PM
Pete000's Avatar
The euro H-4's seem to be the easiest. You will need a plug adaptor they sell at Pelican. If you go with low watt bulbs should be plug and play. If you want the flame throwers you will need to do a relay. Not all that hard. I am saving up to do this upgrade my self.
Work to Live, don't live to work...
Old 09-09-2005, 12:12 PM
JoeP's Avatar
USE RELAYS if you install brighter bulbs. I tried to go from 55w to 80w without one. It took a few months, but it toasted the stock connectors to the bulb, melted the turn signal and headlight switches, and damaged miscellaneous parts of the wiring harness. $700 in parts & labor to fix. Not good.
JoeP
'93 RS America
'87 Carrera (for sale)
'96 Impala
Old 10-20-2005, 07:43 AM
JoeP,
How (where) did you install the relay in your wiring layout?
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 10-20-2005, 12:55 PM
JoeP's Avatar
I wussed out with my 911 and re-installed stock bulbs. However, I did upgrade a 5.0 Mustang that worked flawlessly with Bulb-zillas installed. I bought the wiring harness from "Competition Limited", and it was spectacular:
http://www.hioutputbulbs.com/compt.htm
If big bulbs didn't damage the plastic Mustang lenses, our glass Porsche lenses should perform even better. The kit even supplied high-temp plugs that went into the back of the bulbs because stock plugs can melt, even if you install relays. Given them a call if you have specific questions. They won't steer you wrong.
JoeP
'93 RS America
'96 Impala
Old 10-20-2005, 09:28 PM
A lot of people are going with the "silver stars" from Sylvania. Apparently you get much better light with a simple plug and play bulb.
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/HighPerformance/Silverstar/default.htm
Old 10-21-2005, 02:31 PM
JoeP's Avatar
True, but no matter what color balance you prefer, you have not lived until you uncork a pair of well-installed 100/130w bulbs on a dark road. "Ready photon torpedos, Mr. Sulu."
JoeP
'93 RS America
'96 Impala
Old 10-22-2005, 08:42 AM
Banned
Go xenon.,it's easy,bit expensive, but worth it by the mile,cheers, Antonio.
Old 10-23-2005, 08:18 AM
JoeP's Avatar
I forgot something: 100/130w or 80/100w bulbs were about $15 each, and the high-capacity harness and relay setup was $40.
JoeP
'93 RS America
'96 Impala
Old 10-24-2005, 05:54 AM
Hi Everyone...
I'm new to the Porsche scene. I just bought a 1993 RS America and find the headlights to be dreadfully poor.
On my M5, I did an H4 conversion with HIDs and the combination, while more costly than just the bulb upgrades, is worth its weight in gold. I want to do the same thing for the Porsche.
Where is a good source to get the Euro H4 upgrade housings? I looked around Pelican, but don't see a complete housing upgrade it seems. I seem to be able to find a lense upgrade, but from what I understand, the reflectors inside the headlight are also different and a proper upgrade will require the complete housing.
If anyone can point me in the right direction, I'd be very appreciative. Thanks!
-Stan
1993 RSA #164
Old 10-25-2005, 08:48 PM
