1994 993 engine stalling problem
Can anyone help ? Recently brought a 993 C2 (1994) , untuned, standard set-up. Engine has been stalling randomly two or three times every couple of days. No miss fires, just completely stops. Takes 7 or 8 attempts to restart, whilst trying to start engine does not fire at all, then when starts runs perfectly! It stalls both when idling and when driving along. Have checked eletrical connections and earths etc., but unable to identify a problem.
Faulty DME Relay symptoms. Cheap and easy to replace.
Here is a little light reading: http://forums.rennlist.com/rennforums/showthread.php?t=224957 |
Thank you all for the advise. I am picking a new DME relay up on friday as mine has the 944 numbers on it.
| All times are GMT -8. The time now is 12:23 PM. |
