-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Litronic troubleshooting (http://forums.pelicanparts.com/porsche-964-993-technical-forum/242867-litronic-troubleshooting.html)
glenndeweirdt 09-25-2005 02:23 PM
Litronic headlight on my '99 996 is Kaput. This was a retrofit with used factory lights (Ebay) without the litronic wiring harness. Tried replacement of bulb-no go. Is the control unit the likely culprit? Is it replaceable? Other possibilities?
AFJuvat 09-25-2005 08:08 PM
You probably popped the control module.
993.631.193.02 is the replacement part for the control module.
double check your fuses before shelling out the cash for the box.
AFJ
glenndeweirdt 09-26-2005 06:40 AM
Thanks. You were very helpful with my earlier post on this topic. I found two units on ebay for under $800 with shipping. Of course, this is the risk we take on Ebay. Brandywine Porsche had the complete kit for $1099 a few months ago but by the time I got around to contacting them they were up to $1499.
That may have been the better way to go.
Glenn
glenndeweirdt 09-26-2005 06:42 AM
Also, the other lights work (Fog, turn, hi beam) so it's not the fuse. Could it still be the control unit?
