another a/c problem
I have a 95 933 and have a refrigerant leak. The other day when I switched from the heater to a/c I heard a hissing noise from behind the dash. I immediately suspected a refrigerant leak, which was confirmed when the a/c would not produce any cold air. Anyone have any suggestions where I should start to run this one down? Thanks for any help!
Expansion valve or evaporator core
AFJ |
What should I be looking for in the area of leak, will there be an oil residue?
The hissing noise might have been one of the servos actuating. That’s not a big deal.
I think to find small AC leaks, they put a dye in the refrigerant. Sometimes it is UV sensitive. A black light is used to find the leak. For a good reference, go here: http://www.porsche964.co.uk/ Click on “Technical” then “electrical repairs and modifications” and then the last one: “964 heat and vento servos.” The 964 and 993 are very similar in this area. |
| All times are GMT -8. The time now is 01:19 PM. |
