Send a message via Yahoo to k3racing
Unhappy another a/c problem
I have a 95 933 and have a refrigerant leak. The other day when I switched from the heater to a/c I heard a hissing noise from behind the dash. I immediately suspected a refrigerant leak, which was confirmed when the a/c would not produce any cold air. Anyone have any suggestions where I should start to run this one down? Thanks for any help!
Old 10-11-2005, 09:05 PM
AFJuvat's Avatar
Expansion valve or evaporator core
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-12-2005, 06:48 AM
What should I be looking for in the area of leak, will there be an oil residue?
Old 10-12-2005, 12:50 PM
kang's Avatar
The hissing noise might have been one of the servos actuating. That’s not a big deal.
I think to find small AC leaks, they put a dye in the refrigerant. Sometimes it is UV sensitive. A black light is used to find the leak.
For a good reference, go here: http://www.porsche964.co.uk/
Click on “Technical” then “electrical repairs and modifications” and then the last one: “964 heat and vento servos.” The 964 and 993 are very similar in this area.
Downshift
Old 10-12-2005, 01:48 PM
