Disconnecting the battery
Will I lose the radio functionality? I still have the original CR-1 cassette head unit.
What else will get affected other than losing the DME memory.
Just wanted to be on the safe side before I disconnect the battery for cable and tray maintenance.
Thank you in advance.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 12-30-2005, 03:55 PM
Don Plumley's Avatar
Unsure about the CR-1, some radios need the security code after losing power. Should be in your Owner's Manual or on a key tag.
Don Plumley
M235i
Old 12-30-2005, 05:28 PM
I don't have the stereo code.
I am not even sure if this head unit requires one.
There is also a blinking red alarm led on the face panel.
I will try the dealership to inquire about the stereo code.
Thanks for the reply.
Old 12-30-2005, 08:07 PM
Found the Radio anti-theft security code card inside the glove compartment.
Got separated from the owner's manual bag.
Now I can start disconnecting the battery.
Thanks.
Old 12-30-2005, 08:32 PM
