Trickle Charge Battery 964?
as I do not use the car regularly,my battery seems to drains rather quickly(probably because of the alarm )
I was thinking of installing a plug to make it easy to trickle charge the battery when the car is not in use -without disconnecting it -A friend told me I should not do this as it could damage the electric circuit and/ or alterantor
Is this true ?
Is there a maximum amperage to trickle charge ?
Peter
Old 12-28-2005, 07:29 AM
Tom W's Avatar
Trickle charge just means low amp charging (about 1 amp).
I have a basic Sears trickle charger that I use with my car. It came with both alligator clips and a harness that can be hard wired so you simply plug the charger into it (it gets wired to the battery).
Use of a trickle charger without disconnecting the battery will not cause any problems for the car or battery.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 12-28-2005, 09:25 AM
Thanks ,Tom
Peter
Old 12-28-2005, 09:30 AM
stevepaa's Avatar
I used the Sears trickle charger over a long time, about one year, and a lot of water evaporated and one cell stopped working. Bought a new battery. I would suggest either the Porsche approved trickle charger or a motorcylce style that checks the voltage and only applies current when necessary.
steve
old rocket inguneer
Old 01-03-2006, 12:23 PM
Bill Verburg's Avatar
I use floats on mine. A float has a chip in it that varies the current of the charging circuit from 0 to ~3 or 4amps @ ~14v or so. You won't overcharge the battery as it shuts off when fully charged then turns on again as needed. A trickle is always on at a constant current and needs to be monitored
there are 3 basic kinds
permanent mount on the side of the battery(I have a Schumacher and will buy another)
separate that is connected by clamps to the battery post(can be a PIA) on a 911, 964 or 993 has more room( I also have one of these, the advantage is that it can also boost at 30amps)
separate that connects through the cigarette lighter(this is the way the factory ones connect)
Bill Verburg
Old 01-03-2006, 03:00 PM
