C2 tranny vs. C4 tranny......>
Is there any reason one should not use a C4 6 speed in a C2...???
The reason I am asking the question is because I bought a used 6 speed to put in my C2 & was not informed prior to the purchase that it was out of a C4.
The tranny has been installed & is working fine, but I was wondering if problems could arise.
What about power transfer (read loss) as there are no front drive wheels?
Thanks in advance,
- Cam
If there are no dogs in Heaven, then when I die I want to go where they went.
-Will Rogers
1999 996 FOR SALEhttp://forums.pelicanparts.com/3788325-post1.html
Old 07-03-2006, 09:34 AM
The only downside is the weight penalty of the VC (viscous coupler).. A little late now, but the VC can be removed with just removing the front cover to gain access.
Old 07-03-2006, 08:31 PM
Here is what the VC looks like... Its held onto its shaft by one small little snap ring
Old 07-04-2006, 12:01 PM
Ecellent info...thanks alot.
I do wish I had known earlier, but at least it is down low & centered......
-Will Rogers
Old 07-05-2006, 04:08 AM
and being driven with each pulse of the engine forever robbing you of precious HP
No sweat. Actually, this can be removed with a partial engine drop-- meaning, one can tip the trans nose down enough to gain access to the front cover and subsequently the VC. Shouldnt be too much work..
Old 07-05-2006, 05:26 PM
It seemed to not have as much pull in 4th & 5th, I thought I was imagining it......I will have to
do this when I get the opportunity, thanks.
- Cam
-Will Rogers
Old 07-06-2006, 04:06 AM
Bill Verburg's Avatar
Correct me if I am mistaken, but wouldn't the AWD nose piece already have been removed to install the 2wd nosepice for installation in a C2.
C2 g50 nosepiece and mount, the rubber transmount goes in the hole at the left
C4 g64 nosepiece and mount, transmount is below the pto case
Bill Verburg
Old 07-06-2006, 06:03 AM
Thanks guys.....I will be contacting my mechanic today or tomorrow, & inquire as to exactly what he did for installation.
-Will Rogers
Old 07-06-2006, 06:35 AM
Just an update for the guys that replied.
My mechanic said the VC had been removed.
Thanks for all the help,
- Cam
-Will Rogers
Old 07-10-2006, 06:04 AM
