996 x51 option
salesperson told me a 996 equiped with X51 engine option has different pistons and heads, anyone know if this is true?
It is an increased HP kit for the engine. The contents of the kit are not defined. I know based on earlier kits, they definately had different camshafts. I would not rule out new pistons, but there isn't a listing of what is changed in the dealer order guides.
FWIW, it is a $16000 option. AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
May'be that would explain why the car with the X51 option seemed to have a noisey valve train also?
Go to rennlist.com My buddy has a 2003 996 x50 he said it is upgraded turbo and was told tranny until it broke and found out it was the same tranny as a stock 996 also the muffler has baffle removed. Thats about it no head work or different cams. Has carbon package cost the same as the x-50 option 15k. In 2005 the turbo s is the X-50 they made the car with all the pre x-50 option.
Umm... a 996 TT X50 is a 996 TT with a GT2 motor.
Yes, it has the same transmission as a regular 996 TT So does the GT-2 AFJ
