david dolan's Avatar
Trunk Light Wiring Diagram for a 993
Hi,
Can someone post the wiring for the trunk light? I'm trying to figure out why this light won't work and knowing the correct colors and where they come from and go to would be appreciated. The car is a 1995 993 C4.
Thanks!
David Dolan
1995 993 Carrera 4 India Red
1979 911 SC Targa Metallic Black
Old 08-14-2006, 12:04 AM
Hello??
Anyone out there??
David Dolan
Old 08-15-2006, 09:48 PM
Bill Verburg's Avatar
It' just a simple 2 wire circuit br/wt, red
Fuse#11
Bill Verburg
Old 08-17-2006, 05:24 AM
kang's Avatar
Check the fuse and the bulb, of course, but also check the switch.
Do you get 12V to the socket? Check it with a VOM.
What other tests have you made?
Downshift
Old 08-17-2006, 08:01 AM
Problem Solved!
Should've looked a bit closer at the fuse, from above it looked OK, only when I pulled it did it show the broken wire. I'm sure there's a lesson here somewhere.....if I'd have only kept my mouth shut a bit longer...mutter, mutter.
Thanks!
David Dolan
Old 08-24-2006, 08:13 AM
