Cranks - but won't start
Have low mileage (62K) '92 C2 Roadster. Drive only on weekends, and when last parked ran just fine. Had disconnected battery to charge - reconnected 2 weeks later to go out for drive. Engine cranks just fine, but won't start. Seems almost like either the security system is preventing start-up (although all indicators would indicate its operating fine) or that is not receiving fuel, but can hear fuel pump operating and tank has gas. Any ideas welcome?
Old 08-27-2006, 10:00 AM
kurquhart's Avatar
The first thing i woudl check would be the DME relay:
http://p-car.com/diy/relay/
This is a 993 page, but applies equally well to the 964.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 08-27-2006, 10:10 AM
colo964's Avatar
Are you sure that is the fuel pump? More likely what you're hearing is the brake booster pump.
DME relay is a good starting point also check fuse 34. If you jump 87a (to pump +) and 30 (from batt +) in the relay socket, you can actually check the fuel pump's operation with everything else quiet.
Old 08-27-2006, 11:57 AM
Thanks guys!, replaced the DME relay this morning - and everything runs fine
Old 08-29-2006, 05:22 PM
