-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Phase 4, done :) (http://forums.pelicanparts.com/porsche-964-993-technical-forum/302016-phase-4-done.html)
Bill Verburg 09-01-2006 05:25 PM
Phase 4, done :)
Phase 1, RS Aerokit :)
Phase 2, RS brakes :)
Phase 3, G50/30 Cup transmission :)
Phase 4, Full JIC Comp suspension, TRG adjustable bars, lowered, corner balanced, Unbelieveable handling :)
http://forums.pelicanparts.com/uploa...1157160102.jpg
http://forums.pelicanparts.com/uploa...1157160193.jpg
http://forums.pelicanparts.com/uploa...1157160276.jpg
Don Plumley 09-01-2006 06:05 PM
Woo Hoo! Glad to see the JIC's finally mounted and set up!
Bill Verburg 09-01-2006 06:08 PM
Me too :)
Silveresrty911S 09-01-2006 07:29 PM
WOW Bill!
She looks great, I bet it handles better.
Bill Verburg 09-03-2006 07:06 AM
The difference is night and day, I was somewhat concerned tht the monoballs would make the ride too harsh for street use, but that is not the case at all.
Tom W 09-03-2006 09:16 AM
Bill: It looks great! I'm in the process of going to full monoballs. Had the rear changed before the last race and it was much more planted. The front is being done now. I can't wait to get it out again at the end of the month - I also am having EVO uprights installed with a bump steer package - and want to see how much that helps (it darn well better eliminate the problem).
Did you opt for the mid range JIC springs or the firmest? I had the mids for the last 3 years but am at the point now where they are too soft and will be going to more firm springs too.
Bill Verburg 09-04-2006 01:27 PM
Thanks tom, I went w/ the 7/10(392#/560#), 8/12 are still on the shelf. Your skill set is way beyond where I am.
I thought about the EVO kit but thought I'd ty this first.
Biggest problem so far is that I had to raise the ramps on my lift a full inch to get the car in the garage.
Bill Verburg 09-04-2006 01:48 PM
spring rate discussion
<pre>
JIC 7/10 linear
N/mm kg/mm lb/in
68.7 7 392
98.1 10 560
JIC 8/12 linear
N/mm kg/mm lb/in
78.5 8 448
117.7 12 672
993RS progressive
N/mm kg/mm lb/in
43 4.4 246
80 8.2 457
GT2 light
N/mm kg/mm lb/in
270 27.5 1542
296 30.2 1690
GT2 stiff
N/mm kg/mm lb/in
320 32.6 1827
350 35.7 1999
M030 progressive
N/mm kg/mm lb/in
26.3/35 3/4 150/200
39/48 4/5 225/275</pre>
PorscheGuy79 09-04-2006 04:20 PM
Simply...perfect.
Tom W 09-04-2006 04:28 PM
I'm not sure that I'm all that good, but I'm getting better all the time and having a great time doing it!
I'm likely to start at about 600/800 and see how it goes. I'm starting to push pretty hard and am having some issues with the bias ply slicks in the rear. The guys at the shop believe I'm weaing the inside edges excessively due to changes in toe with suspension travel. They will be removing the springs and raising and lowering the car with a jack to determine the changes in toe and camber through the suspension range. It is believed that simply reducing the amount of range in the suspension will help.
With the switch to monoballs in the rear I've reduced the amount the slicks are rolling onto the sidewalls (despite proper pressures). It made a significant difference in the grip. I'm hoping the front goes as well. I'll know in a couple weeks as I have a 3 day weekend at the track coming up.
Bill Verburg 09-05-2006 04:47 AM
Why aren't you using radial slicks?
kang 09-05-2006 07:23 AM
GT2 stiff
N/mm kg/mm lb/in
320 32.6 1827
350 35.7 1999
Yowsa! At that rate, why bother with springs at all!
Tom W 09-05-2006 08:50 AM
Bill: Class rules require the Goodyear R600 compound slicks in 10.5x23.5x16 and 13x25x16 sizes. That way we all run the same tires and they last 2-3 weekends. The class is desined to limit hp (to about 300 due to running stock intake), weight, and handling (tires) to even out the cars and differentiate the drivers.
DW SD 09-05-2006 09:02 PM
SWEET! Great job - really looks outstanding! Your 3.8 would suit that very well!
Doug
Foto Veloce 09-08-2006 07:51 AM
Very nice. I'm considering the CROSS setup.. any thoughts? Also.. those wheels. I hesitate to ask what they are because I liekly don't want to spend that much money but sheesh.. those are just nice! Cool ride!!
Bill Verburg 09-08-2006 10:52 AM
IMO JIC Cross is the only way to go,
* great selection of springs
* monoballs and camber plates are included
* adjuster is more positive than PCCB
* ride height and corner weight are independantly adjustable
The rear drop links are a bit of an issue w/ TRG sways
axl911 09-08-2006 11:58 AM
What suspension did you have on there before? If it's Bilstein or the M030 spring, I am interested.
thanks,
anthony
Bill Verburg 09-08-2006 12:33 PM
I took off ROW M030/Monroes and ROW M030 sways
axl911 09-08-2006 12:53 PM
I am interested in the package. Give me a call at 214-783-6678 if it's available.
thanks,
anthony
Bill Verburg 09-08-2006 02:14 PM
thanks,
anthony
I haven't decided what i want to do w/ them yet.
