Bill Verburg's Avatar
??spring rates??
i'm tring to figure ou which set of springs to start out w/ on my JIC suspension setup.
The JICs appear to be much stiffer than the other usual suspects in the suspension upgrade department.
But...
I started looking at 993GT2 springs and was shocked.
JIC
kg/mm	   lb/in     kg/mm	 lb/in
7 391.1599974 10 558.7999963
8 447.039997 12 670.5599956
GT2
N/mm	kg/mm	lb/in
270 27.5 699.3213722
296 30.2 766.6634303
Did i mess up somewhere?
Bill Verburg
Old 06-01-2006, 05:18 PM
Tom W's Avatar
The 7/10 JIC are the middle range? I never did the calcs, but they are more than firm enough for me. I run mine at about -6/-4 from full firm (IIRC) and have been making them softer as the year progresses (and getting faster). FWIW I have 25/23 for sways set at middle/soft.
Setting the JICs at full firm or -3/-2 made cornering difficult and I got a lot of wheel hop in tighter corners. Softer was better. I will continue to play with the settings at Sears Point on Monday.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 06-01-2006, 08:59 PM
Don Plumley's Avatar
Bill - your first set of numbers converting kg/mm to lb/in work for me. I found this online:
1 newton = 0.2248089 pound-force
1 millimeter = 0.0393701 inch
0.2248089/0.0393701 = 5.710143
N/mm * 5.710143 = lb/in
So 270 N/mm is some 1541 lb/in. Something's not right...
Don Plumley
M235i
Old 06-02-2006, 08:05 AM
The #s for the GT2 came directly from the factory manual.
270-320 N/mm front
296 - 350 N/mm rear
when compared to the JIC or others that is incredibly stiff.
My feelings are w/ Tom, around here the both track and street are pretty lumpy.
Don, Have you gotten yours on the road yet?
I'm thinking the 7/10 would be a good place to start.
Bill Verburg
Old 06-02-2006, 11:51 AM
I drove it home on Thursday. I have the middle set - 8/12 if I recall. Going down a driveway it lifted a front tire easily. On bumpy road surfaces, it's by no means comfortable. But I had the adjusters pretty tight, it would be interesting to see the difference with them on full soft.
I think that Bob recommended the 7/10 for mixed use, but with my 90%+ track in mind, we went with the next stiffer. It's pretty stiff, I'm running it at Infineon on Monday and will have a better idea.
Don Plumley
M235i
Old 06-03-2006, 08:17 AM
Agreed
here's the updated data
JIC 7/10 linear
N/mm	kg/mm	lb/in
68.7 7 392
98.1 10 560
JIC 8/12 linear
N/mm	kg/mm	lb/in
78.5 8 448
117.7 12 672
993RS progressive
N/mm	kg/mm	lb/in
43 4.4 246
80 8.2 457
GT2 light
N/mm	kg/mm	lb/in
270 27.5 1542
296 30.2 1690
GT2 stiff
N/mm	kg/mm	lb/in
320 32.6 1827
350 35.7 1999
Bill Verburg
Old 06-03-2006, 05:09 PM
Tom W's Avatar
Bill: do you happen to know the colors of the JIC springs? I've always thought I had the 7/10 but the info that came with did not specify what they were. Mine are purple.
Tom
Old 06-03-2006, 09:29 PM
Tom - Mine are purple and are 8/12. That's the middle one.
Don Plumley
M235i
Old 06-03-2006, 10:04 PM
They are all purple, marked on the ends
7kg/mm is 11.25mm wuire
8kg/mm is 11.62mm wire
10kg/mm is 12.2mm wire
12kg/mm is 12.63mm wire
they are also available in 9 & 11 kg/mm for 993/964 use
Bill Verburg
Old 06-04-2006, 10:45 AM
Purple is my only complaint.
Bill - my fronts out of the box had the helper spring on the bottom of the shock if it matters at all:
Don Plumley
M235i
Old 06-04-2006, 11:12 AM
Tom W's Avatar
Thanks guys. Was sure I had the middle of the range, but I have not paid too much attention in the last couple years (other than using them ). I no longer have the helper springs as they were removed to allow the car to get really low.
Tom
Old 06-04-2006, 12:00 PM
What are you guys running for ride heights?
Interesting about the helper spring positioning, these came off a 993, I believe that VB did the install when he was a Ca. resident.
The straight drop link worked w/ TRG bars, but not in all positions.
Your front camber plates appear to be different as well.
Bill Verburg
Old 06-04-2006, 01:50 PM
Tom W's Avatar
Bill: I'm off to Sears Point in a few minutes. I'll take some pictures and real measurements while there.
My 3.25" clearance jack will not fit under the jack points on the car, so it's a bit low. As they have it setup, I do not have any significant issues with bump steer. It likes to dance a bit under heavy braking, but I think it's more toe related than bump steer.
Tom
Old 06-04-2006, 03:58 PM
ted ted is online now
likes to left foot brake.
ted's Avatar
Are what you calling a helper spring the same thing as a spring tender?
Is it common to run coil overs with out spring tenders?
Old 06-04-2006, 04:15 PM
Yes
and
yes
Bill Verburg
Old 06-04-2006, 05:45 PM
GT2R's Avatar
Bill,
The 993RS springs are too soft for track use. I would shoot for a higher spring rate than that.
For the GT2, what color Motorsport spring is your data referring too? In addition to several different colors (blue, yellow, purple,...) , you can add the Versa Spring to these springs which allows you to stiffen each Motorsport spring incrementally. If you have spring rate data for Motorsport springs by color, I would love to have it.
1980 GT3R for sale
1997 993 RSR GT2R-SOLD
1985 930 EFI-SOLD
1979 SC Euro-SOLD
Old 06-05-2006, 01:17 PM
This is from the GT2 competition manual
non adjustable main springs front are *140-60-260 or 140-60-280 or 140-60-300 N/mm non color coded w/ a 40-60-30 helper
helper springs rear are 60-60-30 N/mm non color coded
The adjustable springs are 140-60-X so fronts and rears can be used interchangebly, each of these has 4 adjustments, I only included the lowest and highest in this table.
GT2	       N/mm    kg/mm	lb/in	N/mm	kg/mm	lb/in
front yellow 270 27.5 1542 320 32.6 1827
rear red 296 30.2 1690 350 35.7 1999
blue 235 24.0 1342 286 29.2 1633
white 284 29.0 1622 333 34.0 1901
I agree the RS springs are too soft the ? is use the 7/10 or 8/12 or buy another set 9 and 11 are also available and what combo to use. I am trying to get as much feedback as possible before I start tearing into this.
just ordered the curved rear drop links, and may have the bodies revalved as well( I know they are adjustable, but word is a revalve may be desirable anyway)
*length-coil diameter-spring rate N/mm
Bill Verburg
Old 06-05-2006, 02:59 PM
GT2R's Avatar
Thanks for the data, I always wondered what the Motorsport blues were.
As far as choosing a spring rate, in my opinion, we always choose too soft. If the car is a track car, get at least the 8/12 setup. I am not familiar with the JIC hardware, but I would also look at the shocks compression and rebound.
Two weekends ago I got several laps in a 993 with PSS9, Pilot Sport Cups, and RS sways. The car did not have enough spring and had too little rear rebound. On the street it was fantastic. I guess there really is not compromise.
1980 GT3R for sale
1985 930 EFI-SOLD
1979 SC Euro-SOLD
Old 06-06-2006, 06:43 AM
Bill - Tom took me for a ride in the Turtle at Sears. You wouldn't be going wrong with the 8/12 if that is what he has.
I have the 8/12 in my somewhat lightened 993 - not that I pressed them at all, but the car was rock solid coming off the berms (also good sways).
Don Plumley
M235i
Old 06-06-2006, 09:41 AM
Tom W's Avatar
The inportant question with the PSS-9s is what they were set at.
I had a student running at Infineon yesterday with PSS-9s on his 993 and it sucked - but it was because his mechanic had them set at full soft. I showed him how to adjust them. I have PSS-9s on my 993 and agree that they are a bit more soft than you would want for a track only car.
I have the middle range JIC springs and think they are just fine for my driving.
Tom
Old 06-06-2006, 10:22 AM
