cruise control problem
My cruise started to work less and less frequently. It is now not working at all. Fuse is ok. What fails on these systems? Is there an achiles heal on the cruise? Kevin
brake light switch sticking/failing??
edit: just to be clear; the brake light switch activated by the brake pedal. |
cruise control servo
the cruise control servo that goes in the engine is what most of the time goes. i have a new on or good used one, let me know..
On 993's, there is a tendency for the clutch pedal to not come up all the way. There is a switch that gets activated when you press the clutch, which tells the cruise to cut fuel. This switch gets stuck "on" when the clutch pedal doesn't come up all the way.
See this: http://p-car.com/diy/pedal/clutchlever.html And this: http://p-car.com/diy/pedal/ |
kang, many thanks for your info concerning the diy sites!!! i've been looking for such info forever! thanks again! tjn/vk
Thanks all for the replies, I will dig in and see what I have. Kevin
Finally got a chance to look at the car today. Kang got this one, clutch pedal a little sticky I guess. Pull the pedal up, and cruise works. Thanks all, Kevin
| All times are GMT -8. The time now is 08:20 PM. |
