Send a message via AIM to gamma
cruise control problem
My cruise started to work less and less frequently. It is now not working at all. Fuse is ok. What fails on these systems? Is there an achiles heal on the cruise? Kevin
Kevin Gildea
71 Alfa
02 R1100s Boxer prep
86 Suzuki RG500
97 993 Cabriolet
06 KTM 625SMC
01 Yamaha WR426
92 KDX 200
85 Yamaha IT 200
Old 09-06-2006, 09:07 PM
maxnine11's Avatar
brake light switch sticking/failing??
edit: just to be clear; the brake light switch activated by the brake pedal.
max
Old 09-06-2006, 09:24 PM
Banned
Sr. Parts-a-Lot's Avatar
cruise control servo
the cruise control servo that goes in the engine is what most of the time goes. i have a new on or good used one, let me know..
Old 09-07-2006, 05:17 AM
kang's Avatar
On 993's, there is a tendency for the clutch pedal to not come up all the way. There is a switch that gets activated when you press the clutch, which tells the cruise to cut fuel. This switch gets stuck "on" when the clutch pedal doesn't come up all the way.
See this: http://p-car.com/diy/pedal/clutchlever.html
And this: http://p-car.com/diy/pedal/
Downshift
Old 09-07-2006, 08:04 AM
tjn tjn is offline
kang, many thanks for your info concerning the diy sites!!! i've been looking for such info forever! thanks again! tjn/vk
tjn/vettekiller
Old 09-07-2006, 07:27 PM
Thanks all for the replies, I will dig in and see what I have. Kevin
Kevin Gildea
71 Alfa
86 Suzuki RG500
97 993 Cabriolet
06 KTM 625SMC
01 Yamaha WR426
92 KDX 200
85 Yamaha IT 200
Old 09-14-2006, 09:31 PM
Finally got a chance to look at the car today. Kang got this one, clutch pedal a little sticky I guess. Pull the pedal up, and cruise works. Thanks all, Kevin
Kevin Gildea
71 Alfa
86 Suzuki RG500
97 993 Cabriolet
06 KTM 625SMC
01 Yamaha WR426
92 KDX 200
85 Yamaha IT 200
Old 09-16-2006, 11:54 PM
