Spoiler Problem
993 (1996 c4 cab) witih automatic spoiler: the manual button works to raise and lower it, but suddenly it won't work automatically. So the moter works, but can find the sensor / sender part that has it raise and lower. Any help would be appreciated. Thanks for the assistance; my first post
Welcome.
It sounds like the spoiler control module which is found under the dash. For more exhaustive resources, here's a link to a search I did on Rennlist . Don
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
What would likely have failed though,
if spoiler deploy automatically and parks at low speed, but won't do anything off the manual control? ![]() Is there for example more than one fuse where I might start looking thanks
Nineteen Ninety One 964 |
I have all spoiler control parts from a conversion to a fixed spoiler. Make an offer if you need parts.
Bob |
What would have failed is either the spoiler control module or the speed frequency converter. Not a fuse, since the spoiler is working semi-auto: You can raise it, and then it senses the car is going zero, so it lowers it. This points to the spoiler control module.
Don.....Correct
![]() After a replacement module arrived (which sadly proved to have wrong number of pins) a subsequent delivery solved the problem thanks again for pointers as always
