BoxxerSix's Avatar
Anyone with PET can you help me out?
I've got a '95 993 with a bad oil leak up on the top right corner of the motor. Pressumably a leaking oil pressure sender, but while I'm in there I want to replace all o-rings and gaskets in that vicinity as I dislike tearing into things multiple times to fix a leak. I'd rather just order all the parts and fix everything while I'm in there and not have to buy a complete gasket set for a couple seals.
I can't find my PET cd and could use some help finding the part numbers for the seals/orings on the aluminum cap that the sending units screw into and for the aluminum cap in the far right corner for the breather tube and hardline to the cambox.
If anyone can lend me a hand I'd greatly appriciate it. The oil is getting all over the exhaust and just making a mess of this poor car. Thanks again folks!
Adam Hennessy
Old 11-14-2006, 07:16 PM
P-Zero Burner
911Urge's Avatar
Have you tried the online version?
https://techinfo.porsche.com/techinfo/pdf/en-us/catalogues/993_USA_KATALOG.pdf
Stephen
2006 997 Carrera S - Sport Chrono, Full Leather
1968 912 - Purchased from Vasek Polak in 1971 and still in the family
1989 Carrera 4 - Andial service history, Sold and missing it
Old 11-14-2006, 07:44 PM
AFJuvat's Avatar
O-ring for aluminum cap: 999.707.314.40
Sealing ring for hose connecting piece: 900.123.106.03
Sealing ring for plug on crankcase: 900.123.140.30
Sealing ring for temp sensor: 900.123.007.30
Breather plate gasket: 930.107.791.02
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-15-2006, 05:16 AM
BoxxerSix's Avatar
Stephen thank you for that link. I wasn't aware the PET was located there and thanks AFJ for locating those numbers and posting here. Much appreciated!
Regards,
Adam Hennessy
Old 11-15-2006, 05:41 PM
