3.6 turbo question--test of knowledge
Other than being beefed up because of the technical bulletin that forbid the use of 18" wheels, is the 964 3.6 turbo front suspension otherwise identical to a narrow body? Put another way, is the hub in the same geometric position as a narrow body car? The answer is yes for the 92 turbo, as the parts are the same as the late narrow-bodied cars. The oddity is that the technical spec. book identifies a narrower front track for the 3.6 turbo. Yes, I said narrower. Knowing the answer helps in determining wheel offsets to use if you update the 964 NB front to turbo knuckle and hub.
And...were black calipers an option on a 964 3.6 turbo?
Thanks in advance.
Old 11-26-2006, 05:26 AM
Chip,
There is a 94 3.6 turbo for sale here in Denver. It has red calipers.
Sorry I can't be of more help.
Bill
Old 11-28-2006, 02:21 PM
Black calipers were an option on 1994 3.6 turbo. On my car it's option code Z95 - Titanium/Black Brake Calipers.
Milan
Old 12-01-2006, 08:16 PM
