993 performance enhancing chips?
Anyone know about the 993 performance enhancing computer chips?
1) Drawbacks? 2) Is it worth it? 3) Which one if any? Thanx SvK |
Your '96 does not work with upgrade chips, you'll need a 97+ DME with the socketed chip.
Talk to Steve Wong. (911chips.com) He reprogrammed the '95 DME for my 95 993 DME engine.
It made a noticeable difference for me. I also have non-stock, more aggressive cam shafts, which necessitated modificaiton to fuel / spark curves. Doug |
As Don said, a '96 can not be reprogrammed. You need to switch to a '97 or '98 ECU and then have it re-flashed. It's a couple grand for a few hp. I don't think it's worth it, but it's always the owners choice.
Why is it a couple grand? Cause the ecu is spendy or cause the reflash is spendy?
The ECU is expensive. The flash "cheap" in comparison. You are likely to get 8-10 hp from it. Not something you will notice on the street with an otherwise stock car.
A '97 up US DME lists for a bit over $2500
Oh I see.
But how do I knowhat 97 ecu I need?? Or are they all the same for a 6 speed manual?? Because I can get a ECU fairly cheap/Free so it wont cost me $2,500 so thats what I wanted to clarify. |
All US cars '97 or '98 w/ drive block use either 993.618.604.10 or .11, basiceely yes all the US 6 spd manuals use the same DMEs
RoW and non-driveblock cars use different parts |
| All times are GMT -8. The time now is 05:49 AM. |
