svonkampen's Avatar
993 performance enhancing chips?
Anyone know about the 993 performance enhancing computer chips?
1) Drawbacks?
2) Is it worth it?
3) Which one if any?
Thanx
SvK
SvK
1996 993
1968 911L 3.0 Carb'd.....(sold)
"I don't even know enough to know that I don't know."
Old 02-24-2007, 03:15 PM
Don Plumley's Avatar
Your '96 does not work with upgrade chips, you'll need a 97+ DME with the socketed chip.
Don Plumley
M235i
Old 02-24-2007, 04:51 PM
DW SD's Avatar
Talk to Steve Wong. (911chips.com) He reprogrammed the '95 DME for my 95 993 DME engine.
It made a noticeable difference for me. I also have non-stock, more aggressive cam shafts, which necessitated modificaiton to fuel / spark curves.
Doug
1971 RSR - interpretation
Old 02-26-2007, 10:26 AM
Tom W's Avatar
As Don said, a '96 can not be reprogrammed. You need to switch to a '97 or '98 ECU and then have it re-flashed. It's a couple grand for a few hp. I don't think it's worth it, but it's always the owners choice.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 02-26-2007, 03:41 PM
Why is it a couple grand? Cause the ecu is spendy or cause the reflash is spendy?
Old 02-15-2009, 09:39 PM
Tom W's Avatar
The ECU is expensive. The flash "cheap" in comparison. You are likely to get 8-10 hp from it. Not something you will notice on the street with an otherwise stock car.
Tom
Old 02-15-2009, 11:53 PM
Bill Verburg's Avatar
A '97 up US DME lists for a bit over $2500
Bill Verburg
Old 02-16-2009, 05:18 AM
Oh I see.
But how do I knowhat 97 ecu I need??
Or are they all the same for a 6 speed manual??
Because I can get a ECU fairly cheap/Free so it wont cost me $2,500 so thats what I wanted to clarify.
Old 02-16-2009, 09:42 AM
All US cars '97 or '98 w/ drive block use either 993.618.604.10 or .11, basiceely yes all the US 6 spd manuals use the same DMEs
RoW and non-driveblock cars use different parts
Bill Verburg
Old 02-16-2009, 01:17 PM
