Rear Caliper inserts question
I did a brake job on my 90 C2 this weekend. The damper inserts for the rears were not the right size, although I verified the part number. There were none on the pads I removed.
The calipers on the rear are 2 piston. Does anyone know the insert diameter I need? These things are squeeling more now than they were before. |
Should be a 996.352.086.01
2 required per caliper. AFJ |
Thanks, but 964-352-096-01-M260 Is what I ordered. and they are too small. Evidently, Porsche tried a couple of things with the inserts in 90 and 91 and there are a couple of variations.
Just talked to someone who said I needed a 44mm damper, which is 965 351 096 00. |
| All times are GMT -8. The time now is 08:06 PM. |
