Replace power window switch
The switch just failed for good. Feels like a part inside the toggle broke loose. How do I replace the switch, does the door panel need to be removed? '95 993.
'95 993 C2 Black |
Nope, no need to remove the door panel. The switch just comes straight out. Gently pry it with a screwdriver, if needed. Pull the plug off the back, plug into the new switch, and push the new switch into the door. It's about a 30 second repair job.
Some people have had success repairing the old switch. Take it apart, drill out the broken plastic piece, and replace with a tiny piece of metal, like a short section of a paper clip. Good Luck!
Downshift |
Perfect, thanks. Now, I can't spend just $15.00 at Pelican. Got to tackle a few more projects to justify shipping....
Dave
'95 993 C2 Black |
