Exclamation Bilstein PSS9 II - need help with setup.
I'm in a bit of a bind. I got PSS9 Gen II installed on my 993 C4 last week. Driving to Vermont I realized I have a problem. Ride height is way too low. I have damping rate set to 5, but still have right reat tire rubbing fender. Height seems lower at that corner. I can stiffen it further if necessary. But (now that I'm in Vermont) I'd rather get a local to adjust ride height up a bit. But I don't have Bilstein's PSS9 Gen II manual. I can't find it ANYWHERE on the internet. Does anyone know where its posted? Can someone scan and post or eMail to me?
Thanks in advance for any assist!
JD
2003 "4S-look" Carrera, Tip, lapis blue, grey leather. R.I.P 1996 993 C4 drowned in flood. http://www.pelicanparts.com/gallery/ipaqrat
Old 05-06-2007, 05:24 PM
911skb's Avatar
Check over on forums.rennlist.com, they have a much more active 993 forum, you might get a quick answer to your question. Also, try the "search" feature, it might have already been posted before.
Good luck.
Ken
'92 964 C2
Old 05-06-2007, 08:06 PM
Don Plumley's Avatar
Here's a great DIY from a rennlist member: http://forums.rennlist.com/rennforums/showthread.php?t=258810
When you say it's rubbing the fender, I think you simply need to roll the fender. Get a baseball bat and start rolling!
Don Plumley
M235i
Old 05-06-2007, 08:38 PM
