-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 C2 front sway bar mount broken? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/347717-964-c2-front-sway-bar-mount-broken.html)
Cobalt 05-21-2007 09:38 AM
The front sway bar bushing mount ripped out of the control arm at this weekends AX event. The front clip pulled right out leaving just the bolt holding it in place until it finally came completely apart.
Has any one had this happen to them and is there an improved setup vs the clip and bolt bracket? I would think something so critical should have 2 bolts instead of a clip holding it in place.
Don Plumley 05-21-2007 09:14 PM
I'm guessing the bolt came loose first....
Cobalt 05-22-2007 05:41 AM
Actually the bolts were fine and torqued down. The front clip of the mount just pulled away from the control arm. The bracket itself was all out of shape.
