Cobalt's Avatar
964 C2 front sway bar mount broken?
The front sway bar bushing mount ripped out of the control arm at this weekends AX event. The front clip pulled right out leaving just the bolt holding it in place until it finally came completely apart.
Has any one had this happen to them and is there an improved setup vs the clip and bolt bracket? I would think something so critical should have 2 bolts instead of a clip holding it in place.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 05-21-2007, 09:38 AM
Don Plumley's Avatar
I'm guessing the bolt came loose first....
Don Plumley
M235i
Old 05-21-2007, 09:14 PM
Cobalt's Avatar
Actually the bolts were fine and torqued down. The front clip of the mount just pulled away from the control arm. The bracket itself was all out of shape.
Old 05-22-2007, 05:41 AM
