90 C2 question
Any recommendations for replacing the outer door sill and door seal? Part numbers and removal/install recommendations appreciated.
Old 07-16-2007, 03:13 PM
kurquhart's Avatar
Here's a start:
http://www.pelicanparts.com/catalog/shopcart/911L/POR_911L_BDYsl2_pg1.htm
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 07-16-2007, 06:58 PM
Thanks very much.....looks like a great place to start.
Mitch
Old 07-16-2007, 07:19 PM
Don Plumley's Avatar
Clean the old adhesive out with 3M adhesive remover. Test fit first. Use 3M super weatherstrip adhesive to install. Start with the 90Deg corner, work gently around the perimeter. Don't stretch the seal too much or there will be a loop, but you need a little stretch to make it all the way around.
Don Plumley
M235i
Old 07-16-2007, 09:56 PM
Don and Kris,
Thanks much. The parts have been ordered via Pelican. I'll share the results once completed.
I appreciate your suggestions.
Mitch
Old 07-17-2007, 09:46 AM
Don and Kris.
The parts arrived from Pelican. I followed your suggestions and the instal went perfectly. The door sill and seal look great and match the pass side perfectly.
I appreciate your help on this!
Mitch
Old 07-20-2007, 12:36 PM
