993 Glovebox kicked open
My six year old daughter kicked the glovebox on a drive over the weekend. It won't close and a small U shaped metal item seems to of pulled loose from the frame. There's a couple of screws. If I loosen these can the U shaped latch be inserted and tightened up?
Suggestions or page in the manual to refer to?
Thanks.
Leo
1995 Polar Silver Porsche
Six Speed, ABD, CR1, Has chrome wheels, want to return to "17" light alloy wheels"
Old 10-24-2007, 09:44 PM
Just loosen the two screws holding the metal plate where the U-shaped catch goes in, insert the u-shaped catch in the holes on the plate, then tighten the screws.
Test the glovebox if it locks, if not, loosen the screw once again and adjust the u-shaped catch by pulling it out a little, tighten the screws and test.
Repeat adjusting if necessary until the glovebox stays locked.. Good luck.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-25-2007, 07:41 AM
kang's Avatar
I had to glue the U shaped latch in mine. The screws didn’t seem to hold it tight enough or far enough in. It was simple: loosen the screws, pull the U shaped latch out a bit, put some glue on it, push it back in and tighten the screws. As the screws didn’t seem to hold it tight enough, I had to hold the latch in until the glue set enough to take over. I think I used some 30 second epoxy. This was years ago, and I haven’t had a problem since. On the other hand, I don’t have a six year old daughter kicking it, either!
Downshift
Old 10-25-2007, 09:12 AM
ebenke's Avatar
Ground the six year old for two weeks, then make her help you fix it per instructions above.
E Benke, Florida, USA
1993 964 C2
Old 10-25-2007, 03:47 PM
Bland
unclebilly's Avatar
6 year old kicked it open eh..?
I had a girl friend who once damaged the dash in my corvette with a heel on her shoe... that was 14 years ago but I forgave her pretty quickly.
Old 10-27-2007, 12:08 AM
Mixed up the 2-part JB weld stuff from the auto store and have not had a problem since.
Old 10-27-2007, 01:29 AM
Canadian Member
911Rob's Avatar
There's a guy parting out a 993 on eBay right now...... you might try him if you need a part?
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
Old 10-27-2007, 05:42 PM
Thanks everybody, I've fixed it, without JBweld for the time being.
Used a short phillips and a channel lock to really tighten the two screws. Hopefully it works well. If not, the glue is next.
PS My daughter apologized.....
Old 10-28-2007, 11:35 AM
