turbolook
Engine mount 997 for my 964
Hi everybody
could any body tell if can i change my 964 engine mounts by 997 hydraulic ones? Thanks a lot jc
American Roadster 1992 Turbo Look |
I do not believe so.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
The 964/993 are hydraulic. You can hear the squish in them when you pull them and shake them.
Probably what you want are the Wevo static mounts, infintely better than OEM and you can replace just the rubber which has 2 flavours hard (track use), or medium (street, light track use). There is no better bang for the buck as they're way cheaper than then OEM. Pelican have them for sale. My car improved a lot since I replaced those tired and elongated mounts from 20 years old... Believe me all 964 have the mounts shot by now.
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
turbolook
Thank you
it really help me to decide what exactly my 964 needs. What is the soft one blue or black? Regards jc
turbolook
Thank you again!
I apologize if I didn't ask property. My real question is which cushion is hard and which is soft? JC
I think the black is hard and blue is soft.. I can't remember for sure but in the description it clearly shows which is which. Also you can check Welcome to Windrush Evolutions - WEVO - Porsche Products for more information.
By the way be prepared to adjust the muffler tip cause when you bring the engine up with the new mounts the tip will touch the bumper so you'll have to wrench it loose to re-adjust.
