Newsboy's Avatar
Strange One (noise)
About a month ago I posted info. about a noise coming from the right rear of my 1990 C4. Sounded like a combination of a belt squeak/vacuum leak. It only occurs,
after the engine warms up and the thermostat opens. So I figured it must be oil tank/oil circulation related. We pulled the oil tank and checked what we could see.
No kinked hoses(replaced a bad rubber mount bushing). The noise is still there.
So now I ordered a new tank pressure relief valve(top of tank). Thought that this could be faulty and causing the noise. Any other suggestions, or things to check would be appreciated.
T
Old 10-07-2007, 05:07 AM
AM993's Avatar
I think I have the same issue with my 993. I have narrowed it down to the cooling fan hub bearing and/or the alternator bearing.
'10 997.2 C2 Meteor Gray
'00 Boxster Arctic Silver - sold
95 C2 Polar Silver - Sold
Old 10-07-2007, 05:18 AM
Funnily enough I suspect the same noise on my 964,
can I check the alternator bearing easilly, how much movement should I find by
gripping it with its belts in place
Nineteen Ninety One 964
Old 10-07-2007, 06:36 AM
