Porsche Part Number?
Hello
does anyone know the part number to the 993 RS shift knob/boot? Thank you |
993RS
964.424.015.08 lever 964.424.017.01 fork 964.424.020.35 rod 993.424.075.30 black knob
HI Bill
thank you for responding. I found this part number on the PCA website 993.424.075.30 8YR Does that part number refers to the pic attached? Thanks
yes, it fits over the lever
So that same part number is the same as what is shown on my pic?
Is this an easy to install part? thanks |
If you have an RS lever, yes. If not, I dunno
I am just trying to match that part number to that pic I attached...
Before I make the big puchase just want to make sure that I am purchasing what I see on that pic attahced.... |
I think the actual RS shifter has a printed shift pattern:
![]() The one that you have shown has a '3-D' pattern. It looks like a 996 shifter with a 993 compatible boot. max
max |
Yes , I found out the pic I posted is off a 996 GT3 shifter...
The pic Max posted is the right part number / RS shifter I was orignally looking for and trying to match up.... Next questions for the experts on 993, will the pic I posted (996 GT3 shift/boot) shifter work on the 993? |
I have used a couple varieties of 996 shift knobs on my 993 (using a 993 boot of course) ; and they do fit. some are press on, some have a set screw.
Here's a picture of one that i made. ![]() It is the same knob as the one you pictured, but with an inlay for the shift pattern. The one you pictured must be manufactured by someone making a custom leather boot that mates a 996 knob with the 993 boot console shape.
max |
Max
so you just changed the boot or attached a 993 boot on a 996 shifter? Is that hard to do? That is actually the shifter I like... |
