-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   engine number is 964 and misc 993 dyi questions (http://forums.pelicanparts.com/porsche-964-993-technical-forum/375847-engine-number-964-misc-993-dyi-questions.html)
Leo O'Farrell 11-05-2007 09:50 PM
Hi,
I'm new to the world of Porsche and when changing my oil for the first time noticed the engine number doesn't start with 993. Was the case used (and many other parts) as evolutionary from the really nice looking 964?
So far, new pollen filters installed, front plate bracket and plate installed, headlights cleaned, now oil changed and glovebox fixed. I bought three belts when at parts heaven in Hayward.
The two smaller ones are correct, but the larger AC belt sold to me was 13 x 1085 not 12.5 X 1085 as stated by manual. Would this work or should I take it back?
The clutch pedal made squishy noise and provided a different feeling one day in heavy traffic. This was also after letting my wife use the car. It seemed not to be there the next day.
I thought I just check the fluid level. Any other simple service suggestions?
Bill Verburg 11-06-2007 05:28 AM
The casting # on the block is 964*****, that casting # is used even on 997Gt3 and tt blocks
kurquhart 11-06-2007 07:16 AM
If you search for this part (999-192-363-50-M21) on our host, it is also listed as 13x1085, even though the corresponding parts diagram says 12.5x1085. So my guess is that the 13mm belt will work just fine.
kurquhart 11-06-2007 07:18 AM
Did the use of the 964 block skip a generation? I was under a 996 GT3 the other day, and it had a 996 part number. I was confused because I had been told that the 997 GT3 used the 964 block, so I expected the 996 GT3 to be the same.
Bill Verburg 11-06-2007 07:26 AM
No, all the 996 and 997 GT3 & turbo blocks that I have seen carry the 864 casting #
The normal models of course do not, they have the new style wet sump block
like this one
http://forums.pelicanparts.com/uploa...1194362669.jpg
kurquhart 11-06-2007 02:13 PM
like this one
Hmmm, the block looked very much like my 964 and nothing like my 997 (or your picture). But it definitely had a 996 part number, just to the side of the split case. I pointed it out to the mechanic and he was surprised, too. I guess I should have taken a picture. I called the mechanic to get the exact part number, but the car is gone now but will be back in a couple of weeks; I hope to update this thread later with more details.
kurquhart 03-17-2008 08:16 PM
Sorry to resurrect this old thread, but I finally got pictures of the GT3 block w/ 996 part numbers:
http://forums.pelicanparts.com/uploa...1205810162.jpg
Bill Verburg 03-18-2008 06:02 AM
They must have had new molds made. So much of the bottom end off the 997GT3 and GT3/RS can be used right back to the 964 blocks
flywheels
clutches
cranks
oil pumps
Bill Verburg 03-18-2008 06:05 AM
Here's a 996GT3 w/ 964 casting #
http://forums.pelicanparts.com/uploa...1205845495.jpg
