-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 Ambient Temp indicator (http://forums.pelicanparts.com/porsche-964-993-technical-forum/382051-964-ambient-temp-indicator.html)
simon.marsh@xtr 12-12-2007 01:41 AM
My onboard computer always reads 40.0 degrees C no matter what the temperature is. I think the sensor is located in a mirror. Anybody worked on this before?
dick911 12-16-2007 10:27 AM
I have had this also after removing my mirrors and placing them back: also 40 Celsius...
Turned out that I switched the cables/connectors at the sensor in the mirror housing. :o
Good luck,
Dick911
simon.marsh@xtr 12-19-2007 09:27 PM
Sounds Simple, a Christmas job so I can sneak out into the workshop.
benzyne 03-17-2009 07:37 PM
I'm guessing the sensor is in one of the outside mirrors? Can you guys point me in the right direction? My onboard computer has been reading the wrong temps as well, but I did a lot of playing with various things before.
Regards,
Ben
gizmofixer 03-18-2009 07:54 AM
The sensor should be in your left side mirror.
there is a hole in the bottom of the mirror casing for the temp sensor probe to 'feel' the outside air temp.
See if your mirror has this small sensor tip showing in the hole.
Common failures include corroded wiring or connectors in the mirror housing, failed sensors, and incorrect wiring due to aero mirror upgrades.
benzyne 03-18-2009 11:27 AM
fixed. loose connection at the mirror. thanks!
