tjn tjn is offline
high performance clutch assembly
Hi guys&gals, I have a TT, (1991 Normally aspirated Carrera 4 converted to a TT, )742 HP on the ground. After approximately 3000 miles the clutch will slip in all 5 gears, it is also VERY stiff, lots of pedal pressure! Does anyone have recommendations regarding a different slave cylinder and clutch assembly that will reduce the pedal pressure and hold the torque/hp? Many thanks for your input. TJN/Vettekiller
tjn/vettekiller
Old 12-25-2007, 07:03 PM
Don Plumley's Avatar
I thought S-Car-Go racing in Marin has a high HP clutch solution for the monster motors they make. But a quick check of their website does not list. You might want to call Rob King.
You can also search for user "Poorb0yw" - he installed a Tilton clutch, don't know if he did anything to the hydraulics, but when you see his car, it will be hard to believe he didn't touch it.
Don Plumley
M235i
Old 12-26-2007, 07:43 AM
