Stuttering/Shudder in reverse
Hi.
I am experiencing a very strange stuttering after finishing my 30mile drive home from work. where we stay is on a steep hill and when i arrive and park the 964 with the clutch fully depressed the engine seems to shudder as if its close to stalling...........any ideas?
bryan
Old 12-07-2007, 05:20 AM
do you have a light weight flywheel?
Old 12-07-2007, 05:54 AM
I am not too sure, i can try and check it out..........not owned car for long. could this be part of the problem?
Not always happening, just noticed a few times recently.
Old 12-10-2007, 03:22 PM
i had a ford once and put a 20 lbs flywheel and a real high performance clutch....way too much for the engine.....and it did just that in reverse only.....guess the clutch was catching and releasing over and over
Old 12-11-2007, 09:43 AM
CT944's Avatar
normally that shuttering means the flywheel needs resurfacing. will show up on reverse first before fwd gears.
2007 997 TT
1992 500e
Old 12-15-2007, 06:04 PM
