Whats this switch do?
on side of centre 'tunnel' just by left Knee,
fitted into that small removable panel (which hides rear wiper relay)
a single aftermarket switch and LED which flashes with switch ON
my car has One, and just spotted it fitted on this one in its picture as well
Nineteen Ninety One 964
Old 12-13-2007, 12:30 PM
Don Plumley's Avatar
Must be some sort of aftermarket alarm.
Don Plumley
M235i
Old 12-13-2007, 01:10 PM
Bit confusing actually,
Quite why it has Two LED (one under rotary) one on 'tunnel'
Thought it was just my car, untill I noticed exact same thing in that picture as well
Old 12-13-2007, 01:19 PM
kurquhart's Avatar
Just a guess: aren't all UK cars fitted with "immobilisers" required by the insurance companies?
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 12-13-2007, 03:16 PM
Your quite right on the immobilizer issue,
Not sure quite what happens on the LED front though, I've not seen a car with Two on yet, or one that's switched on or off, via a switch in such a visible place.
'Valet' buttons are normally kust a push button and mounted out of sight (no LED) AFAIK
Cheers Richard
Old 12-14-2007, 12:37 AM
Right, just been informed its a switch and LED to disable alarms internal sensors, when you leave a dog or child say, in locked car.
That makes perfect sense what with a warning light next to switch.
Thanks for suggestions as usual anyway,
Richard
Old 12-14-2007, 02:04 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
OK, I'm going to play too: This is the switch that converts the car from RH (as it should be) to LH drive (for The States).
Do I win a prize????
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 12-15-2007, 10:51 AM
No its the eyeball-brain interface enablement module,
that renders you able to comprehend (already) answered questions
"Do keep up 007"
Old 12-15-2007, 10:56 AM
JOT MON ABBR OTH
Sure the game is rigged, but if you don't play you can't win!
And some wrong answers just deserve to be heard, even if they are rather idiotic...
Old 12-15-2007, 03:50 PM
While I understand its never going to be a dynamic forum, I generally read through the replies before adding,
usually to avoid repostism.
Plus it helps not reinventing the wheel at same time,
but hey, what do I know!
Old 12-16-2007, 03:18 AM
