Now in 993 land ...
OBDII readiness drive cycle procedures
I disconnected my battery 3 weeks and 500 miles ago. Went to smog the car with no ill thoughts and did not pass due to readiness code(s) not set. If I remember right (I am out of town) My INNOVA 3100 code reader (http://www.troublecodes.net/articles/equus/Equuis_OBD_II_code_reader.shtml) tells me I am still missing the following readiness codes:
C = Catalyst Monitor EV = Evaporative System Monitor 2A = Secondary Air System Monitor O = Oxygen Sensor Monitor I know that Don has posted extensively on how to pass smog with the SAI readiness code not set. However, I obviously have a whole bunch of codes not set. I am not too surprised, as I am not driving the car much and of the 500 miles there is one long distance trip with one stop and 300 miles worth of driving to and from the track and a track day ... I have searched the web for drive cycle procedures on the 993 and others. Looks like a bunch of voodo and hard to realize in a populated area. What has worked for you and what do you recommend? I'll be home over X-mas and can experiment. Will I just need more warmup cycles than the handful I have gotten to date? Thanks! George |
For CA smog, I don't worry about the readiness codes. I go firectly to a referee station. Need to make an appt. Telling them my battery died and the codes have not re-set is enough to get one. The nearest one is 5 miles away at the local community college. My last smog, I was one of three 993's in a row.
Didn't cost any more and the tech was more carefull with the car. Even let me let me drive in/out of the shop. Kevin
'96 Coupe - Arena Red |
George - there is a recent post on Rennlist about setting the readiness codes. Here's a highlight:
Don
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
I just did mine in November, and after a ton of research, here is the procedure that worked like a charm for me on the first try: (note: same procedure as the above post)
Once the CE light is cleared the following readiness cycle can be followed to reset the code or you could drive the car for a while in a variety of situations that would allow each system to do it's thing: Start engine, idle cold for approx. 2 min, 10 secs. Accelerate to 20-30 MPH, Maintain steady speed for approx 3 min, 15 secs. Accelerate to 40-60 MPH, Maintain steady speed for approx 15 mins. Decelerate and come to a stop. Idle in gear* for approx 5 mins. *I don't think you actually have to idle in gear unless you have a Tiptronic...I idled mine in neutral. It is absolutely essential to keep the RPM's below 3,000 and the MPH below 60 for the duration of this test. In California, the referee thing seems to be the easiest and most expedient way to go...Unfortunately we don't have that option where I live.
Jack 2007 GT3 gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B Last edited by jackb911; 12-19-2007 at 08:17 PM.. |
Now in 993 land ...
There are at least 5 stop signs from my house before I can drive 20-30 mph at a steady speed. Does this mean I start counting once I can drive 20-30 steady?
I tried the above cycle once (with a bunch of stops) and it did not even get one of the readiness codes set. I'll have to try again at night, where I can drive more reasonably - without running stop signs though. Can I look up smog referees online? If I can't resolve this over christmas, it seems that is the way to go. Thanks guys! George |
From the CA DMV Site:
It’s crazy, I know. So do the referees. That’s why you skip trying to set the codes and go straight to the referee.
Downshift |
Now in 993 land ...
I need to park it in the desert overnight. Sounds indeed like the procedure is made for the dyno!
Off to the referee I go. George |
By the way the original "formula" came from BMW. http://srlx.com/p-car/obdii_readiness.pdf
Bill W. '97 Arena Red / Gray 993 Cab '93 968 Coupe 6 Spd '88 911 Cab Red/Blk (sold) Last edited by bill3667; 12-28-2007 at 11:57 AM.. |
One important step I see that is missing and that is the fuel level has to be between 1/2 and full.The control module will add fuel vapor to the engine and monitor the ability of fuel control sensors to read and adjust emissions .I have been a test and repair smog tech for many years [now retired ,still licensed] and the fuel level is critical to passing the drive cycle test.Some cars pass quickly and some take quite a bit of driving.The purpose of the drive cycle is to have the emissions control system test itself while driving and can control emissions.
Driver/ PITA @TSB Racing
Not as of January 2020. |
Please explain "Not as of January 2020."
For the 993 monitors setting procedure read here under Porsche 993 Cycle Flag Basics;
https://www.systemsc.com/codes.htm
Dave |
I’ve been through this with numerous vehicles , following numerous “guidelines” I’d read about online .
The best one for me was half a tank of fuel and drive 20 mins on freeway and back at 56mph (cruise control) Worked perfect , and within an hour I had my smog cert . |
Avoid stalling the engine during a trip or that trip must be repeated.
Dave |
Could these drive cycles be done on a chassis dyno? Much easier to maintain speeds that way.
I need to do something soon, my smog test is due. My battery failed, so of course all Readiness Codes went away. Grrr. Mine is a 1996 993; I live in the Foothills east of Sacramento. |
I got tired of the car and check engine light woes. I sold it.
