993 distributor belt
changing the distributor drive belt on 1995 993. is this a d.i.y. project or dealer only job
Old 01-06-2008, 02:35 PM
kurquhart's Avatar
Depends on how handy you are:
http://p-car.com/diy/dualbelt/
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 01-06-2008, 03:23 PM
Don Plumley's Avatar
There are a few people that do this as a service. Steve at Rennsport Systems in WA and Mark Cohen in NC.
Don Plumley
M235i
Old 01-06-2008, 10:33 PM
Autobahn Garage
I can do it for you as well, P.M. me if your interested
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 01-07-2008, 08:40 PM
that writeup is fine, but you don't have to disassemble it as far as the writer did. the gear and the main shaft assembly is removed as shown, but the other short assembly can be left in place. the allen bolts that hold the upper and lower body together are removed, body halves separated as far as they will go, then the two dowel pins are tapped up out of the way of the gap between the body halves. now the belt can be replaced by slipping it over the lower body shaft and sideways through the gap.
206 637 4071
Old 01-08-2008, 08:23 AM
