Super Moderator
Where the &*^% do my 993 horns mount?
I'm putting together the front of my '96 993 and have nearly the entire right side together... EXCEPT... I can't figure out where the heck the horns go!
I have the non-trumpet style horns and cannot find the mount location in any diagram, neither could the local dealer. Anyone know? Have pictures?!
Behind the passenger headlight. Here is a DIY for an aftermarket horn installation. It should help.
http://p-car.com/diy/horn/
Downshift |
As Kang said, passenger side above the oil cooler
Super Moderator
Thanks, but I don't have the trumpet style horns, I have the small versions...
Totally different bracket... I have the ones on the right of this image...
I dont know if I was looking at a horn or a alarm panic horn but when I was taking out my motor over the weekend on my 95 993, where the rear drivers side torsion tube would be on a tbar car
I see what looks like a horn. But it makes no sense to me that its in the back so it has to be something to do with the alarm. I guess you could connect up the battery and just follow the sound of the horn... wear some ear plugs... |
Super Moderator
Herman,
Thanks. I'm not looking for the horn, I know right where it is. It's sitting on the floor under the right side wheel well. The question is, where the heck does it mount? I can't for the life of me figure out where it goes on the car...
Same place as the trumpet horns, behind the passenger headlight. Check out that DIY.
Downshift |
Super Moderator
Thanks Kang... Of COURSE all the pictures are missing from that article, but I caught just the edge of the bracket in this picture, enough to gauge the orientation and position.
Chris
