-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 engine Management System (http://forums.pelicanparts.com/porsche-964-993-technical-forum/393463-964-engine-management-system.html)
sgoldberg 02-18-2008 06:19 AM
I have a 1989 964. I am replacing my stock engine with a 1993 RSA motor. The motor comes with the brain and proformance chip. I was told that a new engine management system would be very useful ...Haltech etc. which is the best system for my car and what are the cost I could expect to have the system installed?
Thanks,
Shelon
Bill Verburg 02-18-2008 08:27 AM
There are lots of choices, none are cheap. Also depends on if you are keeping the stock intake manifolds or using something different.
Motec is one of the most highly regarded
sgoldberg 02-18-2008 09:42 AM
Thanks Bill - The stock intake will remain on the car.
Tom W 02-18-2008 03:02 PM
Like Bill says, it's not cheap. Select the management system that your shop is going to be able to support. My shop uses MoTeC so it was a lot less problem to switch to MoTeC than to try and get the Motronic system programmed/re-programmed. A MoTeC conversion is likely to run close to $5k for the ECU, wiring harness, and programming time.
sgoldberg 02-18-2008 03:50 PM
Thanks for the info. I guess a chip is my inline with my budget.
strokher racing 02-19-2008 12:05 AM
You are in New York so you should contact Jimmy at The Shop. He is a dealer for Accel Gen 7's.
sgoldberg 02-19-2008 02:22 PM
Do you have Jimmy's contact info? Thanks
strokher racing 02-19-2008 04:50 PM
www.theshopct.com
Tell him Eric Hood sent you
930gt-40r 02-19-2008 07:16 PM
Yea, he does all of those nasty DFI installs.
Fast951 02-22-2008 01:03 PM
Thanks,
Shelon
Why do you think you need a standalone? Is there a issue with the Motronic system?
930gt-40r 02-22-2008 06:00 PM
I wouldnt bother unless you were going to blow into the motor.
sgoldberg 02-24-2008 06:26 AM
I was told that a new engine management system would release hp on the motor. So I figure i would investigate and see what the costs are.
Fast951 02-24-2008 08:56 AM
There are ways to gain control over the factory Motronic engine management. Some of the things that are available for the 964 are: MAF conversion, support to larger injectors, support to LWF and access to fuel and ignition without going the standalone route. If you need more information send me a email.
strokher racing 01-31-2009 02:05 PM
I know this post is old, but I would like to retract my recommendation! DO NOT USE Jimmy Kakaletris owner of The Shop in Norwalk CT. I am beyond mad about my latest experience with him, and his shop!
